Damage inside differential, what to do next?
ROCK HARVEY
Dayton OH
I bought my truck a couple months ago, and have been doing all the fluid changes and routine maintenance stuff. When I went to change the differential fluid, I found some strange damage inside. The cover has a deep dent from the inside, and one of the pinion teeth is chipped (pics in next post). There were no chunks of metal inside, which makes me think this happened a while ago and a previous owner removed the pieces. I hadn’t noticed any strange noise from the rear end while driving, but the truck is very loud so maybe I just didn’t hear it. The fluid did have a metallic sheen, but no gritty particles that I could find. What do you guys think I should do? I haven’t filled it back up yet because I hate to waste $60 of gear oil if I’m going to have to tear it open again in a month. Does this need a total rebuild? Could it last a while as-is?
ROCK HARVEY
Dayton OH
TNBrett
Middle Tennessee
Looks like the differential cross pin walked out at some point. PO probably “fixed” it. If it’s not making and abnormal sounds, I’d say run it. Change the gear oil again in 5-10k miles and reassess. In the mean while keep your eyes open for a decent deal on another rear end. That will probably be the most cost effective solution if it does let go.
ROCK HARVEY
Dayton OH
I think you guys are right. I don’t have much choice right now but to fill it back up and drive it for now. There seems to be a pretty constant supply of people parting out their trucks around here, so it shouldn’t take me too long to find another axle. Thanks.
Jim993
Prescott, Arizona
I agree, you probably have it back together by now, but if not, just make sure that the differential cross pin is secure before putting it back together.
Here's a sampling of the availability and price in Ohio for these rearends. I picked a 4.10 ratio.
994
Rear Axle Assembly
Ford Truck 250
4-94
X​
000091
$550​
Northtown Auto Parts USA-OH(Toledo) Request_Quote 419-531-7777 / 800-430-6610 Request_Insurance_Quote
1996
Rear Axle Assembly
Ford Truck F250
full-floating, 4.10 ratio. Locking, out and ready-175K
175,000​
A​
CM96026
$500​
Kohler Auto Wrecking USA-OH(Garrettsville) Request_Quote 440-548-5817 Request_Insurance_Quote
1995
Rear Axle Assembly
Ford Truck F350
SRW (with ABS), 4.10 ratio locking, Out and ready.
X​
6RAX42
$500​
1996
Rear Axle Assembly
Ford Truck F350
Single rear wheel (with ABS), 4.10 ratio, locking. Full floating. Code C5.
X​
WR209
$500​
1997
Rear Axle Assembly
Ford Truck F250
4.10 LIMITED SLIP
319,817​
C​
19B066
$500​
Miamitown Auto Parts & Recycling - RTN, MIDW USA-OH(Cleves) Request_Quote 513-353-1111 / 800-245-2886 Request_Insurance_Quote
1993
Rear Axle Assembly
Ford Truck F250 not Super Duty
4WD 7.50L
142,756​
A​
MT020034
$450​
Clayton Auto Parts - RTN, MIDW USA-OH(Clayton) Request_Quote 1-800-325-1365 Request_Insurance_Quote
1993
Rear Axle Assembly
Ford Truck F250
full-floating (with ABS), 4.10 ratio Locker. Out and Ready-73143
73,143​
A​
RAX57
$450​
1994
Rear Axle Assembly
Ford Truck F250
full float
X​
180120
$325​
Bedford Auto Wrecking USA-OH(Bedford) Request_Quote 1-440-232-6474 Request_Insurance_Quote
1997
Rear Axle Assembly
Ford Truck F250
C5
292,776​
C​
AA2526
$300​
Affordable Auto Parts & Salvage, Inc. USA-OH(Ashtabula) E-mail 440-997-1541
1993
Rear Axle Assembly
Ford Truck F250
4.10 RATIO LIMITED SLIP
183,000​
A​
PA8563
$300​
Creston Auto Recycling USA-OH(Creston) Request_Quote 330-435-4441 Request_Insurance_Quote
1996
Rear Axle Assembly
Ford Truck F250
4.10L CDE=33 TAN 4X4
227,000​
C​
201206
$300​
Auto & Truck Recycling of Marengo USA-OH(Marengo) Request_Quote 419-253-0403 Request_Insurance_Quote
1997
Rear Axle Assembly
Ford Truck F250
C5 4L10 8800GVW RED 4X4
176,000​
A​
190320
$300​
1993
Rear Axle Assembly
Ford Truck F250
06/93,4.9L,AUTO,XL
230,000​
C​
052101
$300​
Riverside Auto Parts - MIDW USA-OH(Dayton) Request_Quote 937-502-4983 Request_Insurance_Quote
1991
Rear Axle Assembly
Ford Truck F250
4.10 F250/F350 FULL FLOATING REAREND
0​
A​
210426
$250​
Marshalls Auto Parts, Inc. USA-OH(Circleville) Request_Quote 1-800-333-2104 Request_Insurance_Quote
1995
Rear Axle Assembly
Ford Truck 250
12/94,7.3L,5SP,XL DRW
X​
AW1646
$250​
Youngstown Auto Wrecking LLC-RTN, MIDW, ARA USA-OH(Youngstown) Request_Quote 330-743-1492 Request_Insurance_Quote
1995
Rear Axle Assembly
Ford Truck F250
FULL FLOAT 4.10
X​
CW7874
$250​
Wirthman Brothers, Inc. USA-OH(Columbus) Request_Quote 1-800-433-4364 Request_Insurance_Quote
1992
Rear Axle Assembly
Ford Truck F250
4.10 RATIO WILL SEP
235,000​
C​
NE7682
$250​
1997
Rear Axle Assembly
Ford Truck 250 HD
4.10 RATIO FULL FLOAT
172,000​
A​
QG9125
$250​
1995
Rear Axle Assembly
Ford Truck F250
4.10 Ratio, Rear Axle Assy, GOOD
157,251​
A​
150028
$250​
Countyline Auto Wrecking USA-OH(Geneva) Request_Quote 1-800-976-5442 / 1-440-466-5000 Request_Insurance_Quote
1991
Rear Axle Assembly
Ford Truck F250
full-floating (w/ABS), 4.10 ratio
93,000​
A​
130022
$250​
Hi-Way 101 Auto Parts USA-OH(Tiffin) Request_Quote 419-447-7041 Request_Insurance_Quote
1997
Rear Axle Assembly
Ford Truck F250
4X4 4.10 TESTED WARRANTY
141,000​
A​
ADL001
$250​
Adler's Auto Parts and Service USA-OH(Walbridge) Request_Quote 567-249-4693 Request_Insurance_Quote
1996
Rear Axle Assembly
Ford Truck F250
BLUE F250 4.10 PULLED TAG
130,000​
A​
NOF
$202​
K & G Automotive, Inc. USA-OH(Delta) E-mail 1-419-822-3332
1996
Rear Axle Assembly
Ford Truck F250
4.10 FULL FLOAT
215,000​
C​
QI9163
$200​
Knuckledragger
Payson, AZ
The damage was done by a broken spider shaft (maybe just a broken end), it has been repaired. If the scrapes bother you, replace the cover with a clean one. If the chipped pinion makes noise, consider a replacement rear end. Those chips were probably made by the broken shaft when it popped out of the housing. Nice photos!
ROCK HARVEY
Dayton OH
Thanks for the help guys. I was glad to see that axles are plentiful and relatively inexpensive. Does anybody know if a 93+ axle (with the long pinion) will bolt right up to my driveshaft? I know the yokes are different on long and short pinion rear ends, but do they use the same u-joint? If it’s not a hassle I figure I might as well get one of the long pinion axles.
I think it's unusual that when I plugged in a 1989 f250 on www.car-part.com above, that it listed those later rearends fitting. They usually only list direct interchange. Like you, I would have thought you would need a shorter driveshaft or something like that.
Knuckledragger
Payson, AZ
The main change was on the pinion and yoke, not the housing. The yokes are different in that they reach farther into the housing with 1/2" longer splines. I believe that the shaft length is the same, as is the U-joint.
ROCK HARVEY
Dayton OH
That’s what I thought too, that either one would bolt up to my driveshaft. I took the truck for a fairly long drive today, and I didn’t notice any noises from the rear end. I do think the clock is ticking on those bearings given the metallic sheen of the old gear oil, but hopefully I have time to shop around for a good deal on a long pinion axle.
m2rtin
