D60 swap done. finally!
Wicked97
Nebraska
The d60 part was 30 minutes start to finish it just took 4 months to get to it.
At the same time I went with new springs in the rear. That took longer as I just cut all the old springs out with a torch. I'm to old and lazy to fight rusted up suspension.
Anyway using 94 f350 gasser springs lifted the front 1.75 inches and using 5+1 2975lb springs and 08 f350 lift blocks put the back up about 1/4 higher than the front. The front tires are in a hole so it looks a lot lower in the front than it actually is.
Wicked97
Nebraska
Is this what your looking for?
Greg5OH
MI
did you use stock or an rsk for the front spring hangers?
Did you box the frame? Any detailed pics?
Wicked97
Nebraska
All stock.
No shackle reversal or any other mods.
The only thing I did was unbolt the d44 from the truck, removed the springs and d44 pivot brackets and bolted the 60 and 350 springs in.
It was exactly 30 minutes start to finish.
