BigRigTech
Diesel junky
I have a few questions for those of you with Cummins 12V's in your Fords. This is for my 92 F350 C&C 4x4 dump truck. I'm stripping the 92 D350 donor truck right now.
1: exhaust manifold - leave it as Dodge installed it or flip it over to point the turbo up? I also have a commerical 5 ton manifold that mounts the turbo close to the block under the manifold.
2: What are you using for a starter and trans adapter plate? I plan to make my own.
3: What are you using for Fan shrouds and rads? I have a 460 rad and shroud here along with a new Allstar racing rad, all aluminum and big flow numbers.
4: What are you using for engine mounts?
5: What did you use for a throttle linkage and alternator? I would like to adapter my Taurus 3G alternator to fit so I can use my existing wiring.
6: I have a ZF 5spd, how far back did you have to move your trans back and what did you use for a throw out bearing?
7: What did you use for power steering hoses?
I plan to do the KDP mod and tinker with the VE pump....I'm using the stock Dodge I/C if it pass's my pressure test. I may gear up a 4" exhaust as well.
