Crew hauler build
gnathv
Athens, Al
That is the factory timing adaptor for #1 cylinder. It needs to be there. Used with Rotunda timing set up.
gnathv
Athens, Al
If you leave it off you shorten the line and that injector pops early.
Big Bart
Tow&Slow
Newport Beach, CA
Jackranch my 7.3 NA has that too. Mine is also on the #1 cylinder.(Passenger front.) I have seen some Factory Ford Rotunda IP timing tools on EBay. They have a very large clamp for the injector line. Although I do not know this to be true, my thought is IH or Ford put that on there for their IP timing tool to perhaps make a easier/better connection or get a better read on injection pulse. Thus why we have one, only on the #1 cylinder. Let’s see if another member knows if it has another reason for being there or can confirm their Rotunda timing tool uses it. My Tach n Time uses the skinny part of the injector line to clamp on, not that adapter you show above.
JAKRANCH
Benson, Utah
Good to know. That was our debate last night cuz if it wasnt supposed to be there it would explain the poor running issues that led to me buying an expensive new pump. Did not want to tell the wifey that some PO's mechanic left an adapter on and the issues were free to fix:frustrate
TNBrett
Middle Tennessee
I’ve wondered for some time if the factory timing adapter would work with the tach-n-time. My thought is that it should work the same as the clamp on sensor, but possibly be more accurate. It’s just one of those things I haven’t gotten around to yet.
chillman88
Central NY
I seem to remember someone trying that and it working, but don't quote me on it. I also haven't gotten around to trying it.
Big Bart
Tow&Slow
Newport Beach, CA
Guessing if the plug on the cord is the same size that likely it would.
Who knows, maybe Kent Moore built the timing tool for Ford and used the same plug and specs for the sensor.
