Crew cab trim
Weldingman
Pennsylvania
Is there anyone who makes the interior trim pieces for crew cab bullnose fords? I got an 85 crew cab and wanna replace the interior trim and rear door trim pieces.
Weldingman
Pennsylvania
I’ve checked them and bronco graveyard and all I see if for the front doors. Nothing for the rears or the plastic trim.
They are similar up to 1992 I think? Then they change the trim a little, so the interior body lines may not align. I'm in the same boat, need a pair of rear door interior panels. Mine are sun faded something awful.
NeverHave-I-Ether
Texas
Little but of mineral oil will do the trick I've found;)
Never-Have-I-Ether
Weldingman
Pennsylvania
Mine are beyond that. They’re crumbling away to nothing. Another question. Is the B pillar trim the same for standard cabs and crew cabs? I need the trim that goes from the floor up the cab and hold up the headliner.
I doubt it. I think that piece has a curve around to the back side of the cab where the ones for crew cabs are straight at the top, meaning that the top parts of them run straight front and back. The parts that go clear to the floor may be different shaped too.
Weldingman
Pennsylvania
Okay so basically I need a crew cab donor. Can’t really use much off the single or extended cabs.
Weldingman
Pennsylvania
Another thought is if it’s too hard to find the door panel can I swap doors off an obs onto my bullnose?
As far as I know... Yes you can. Body lines are the same. Wiring might need to be adapted.
Weldingman
Pennsylvania
I’m not sure what would need to be wired on the doors. I don’t think there’s anything electrical on mine.
