Crew Cab Door Pins
Pino2234
South Jersey
Are the rear door pins the same as the front door pins in a crew cab Ford?
I have 2 crew cabs and they both need pins and bushings all the way around.
RLDSL
Diesel fuel abuser
Arkansas
They look the same on my 92 as well. I just replaced the front drivers door pins when I swapped a door. If keeping teh same door, only remove one hinge at a time to save having to re-allign the door.
You will need a good grinder to knock the old pin end off and an air chisel with a pointed tip comes in real handy to drive it and the bushings out
Pino2234
South Jersey
Thanks. I just ordered 16 from rock auto for like $2.36 a piece, pep boys wanted $5 each.
