Cp3 pump.
94f450sd
somewhere,ma
Ok I have an 01 2500.that won't start.story I got is they put gas in it,it died,hasn't run since.its not pumping fuel.i can prime it,crank it,no start,no fuel out the valve.
No fuel coming from the valve while cranking either.
Google says the pump is bad.what years interchange???? I've got 6 of these things around here but the easiest one to steal from is in the 05 5500.i know they're different in ways,but is the pump the same?
IDIBronco86
