chris88
I have my eye on a truck. I think its an 87 model year but i cant remeber off hand. Its the same body style as the 88-92. Did they put 6.9/T-18's in that body? I havent seen the truck in a couple months but i'll see it again on wednsday. If its a t-18 i want to swap the trans to an overdrive trans. Are there any other over drive trans that will fit under the cab of a pickup other than a zf-5. I dont have anything against the zf but was wondering if i could put a spicer out of an IH and if it would fit under the cab. What is the gear ratio of overdrive in the zf? If i get this truck i plan on redoing as much as i can. New brakelines front to back, IP and injectors and whatever else it needs. I plan on it being a work truck and a good reliable daily driver.
Thanks
Chris
Thanks
Chris
