i want to build a bored out, sleeved down, stroker 7.3. bored and sleeved back down to 4.1", stroked to 4.36", makin it a 460, a shorter rod and low-topped, ceramic topped piston so it doesnt quite come all the way up the hole, with deep valve reliefs, and deeper valve seats and valves with slightly shorter valve stems (all JUST so it can clear a big, power makin, hydro-roller cam, that i truly believe is the cure to the weak link in these motors). the setup will be slightly decompressed to 19.5:1. of course, with all the portin and polishin (includin and effort to open up the prechambers a little more) moose injection, headers, and a custom intake to support a whipple 8.3L blower.
.......if a blown 427 LSX gasser can make 800 ft-lbs of torque right off of idle, so can my motha f*ckin IDI!
......chastise me if you will, but that build is not a matter of IF i build it, but WHEN i build it. fyi, the gears are in motion, and im already tryin to collect the parts ill need to get started.
