Core support, bushings, water pump, and?
The_Josh_Bear
Western WA
I have another thread about my dumb core support having rust rot and while I wait for the wreckers to get the replacement figured out and sent to me...
I realized my core support body bushings were shot. Best place to get new ones? All I can find are Poly but without the sleeves. (Had to cut one of mine out). And I doubt they are good choice for comfort.
And then I thought...I'm already here...may as well check the water pump for play. Of course it has a small clunk to it. Probably best to get motorcraft for this, eh?
What else should I check since I'm this deep???
Thanks gents!
The_Josh_Bear
Western WA
I looked an it was only the full kit for the whole cab. Which makes sense but at $85 I'd rather pay less than half that since I'm only using 1/3 of the kit.
Dirtleg
Cloverdale VA
While you're in there how's your steering box? Front seal? Brake lines off the master all good?
The_Josh_Bear
Western WA
Thanks for the tips, sterring box is actually a Red Head from 8-9 years ago and solid, front seal looks ok but the front passenger oil pan seal is leaking a bit...
I'll have to check the brake lines!
brb5
