Coolant Issues
ISurvivedNMU
Michigan
I have been reading about coolant overflow when you add a chip to the 6.0..... Is this a specific year problem.... Will it effect my 05? :yell:
ISNMU:drunk:
TooMuchBoost
South of Atlanta
Every year of the 6.0 baby.
Some do it stock and some do it only when modded. The Diablo is the biggest puker of them all due to timing.
Some have had the puking solved by a new cap others have not. One theory is the coolant reservoir is too small. I personally never tried to solve my issue, but kept the coolant at the minimum line without issue.
The Quad 160 wasn't a bad puker, but the Diablo puked every time I put the pedal to the mat and I could smell it in the cab.
While at Sheid's this summer I noticed a brand new dealer's 05 had residue around cap.
timntools
Chief Runinscissors
Hendersonville, TN (Nashville)
from what a tech told me, it has to do with some cooling valve sticking, not letting enough cooling get thru, but said it was mainly on 04's.
but I reckon if you add some timing to the mix, yeah, you're going to have probs. I had the pred in my 04, but it puked coolant if I was timed up or stock.
TooMuchBoost
South of Atlanta
Originally posted by ISurvivedNMU
How bad is the spew.... and it only comes out at the res cap?
Stock or mild timing advance you could notice light colored dribble coming from the neck of the cap onto the reservoir.
The Diablo can [though not always], Diablo stacked with a module or something really geeked with timing will spew down all over the left front suspension.
ISurvivedNMU
Michigan
What does the timing do? Add extra heat to the chamber that can not be cooled fast enough? Or is it a valve issue that might be able to be corrected?
If a power unit will cause that, it must not be that good on the motors longevity!
Motown Fire
Texas
Mine does it also with the Predator on 65hp setting. But it does not seem to come from the resevor bottle.
ISurvivedNMU
Michigan
Welcome motown...
Where does it puke antifreeze from?
timntools
Chief Runinscissors
my 03 never did it. ran quad's first guinipig box and still didn't do it. my 04 did it whether the pred was in or not at all.
05 still too new to tell. been dying to put the pred in to see what it'll do, but skeered to mess up another one.
olsen726
