Coolant in Oil
racer30
western Oregon
Sounds like a leak at the intake gasket could go right into the lifter valley down into the pan. If you reused the gasket it could be your problem.
eatont9999
TX
This is true especially if the CDR tube is not sealing well to the valley pan. Run the truck for a little while and without burning yourself, feel down around the bottom of the CDR tube and if it feels wet, then that could be the cause of the issues.
On the other hand, oil cooler cores can corrode and new seals can get pinched and not seal.
ntjapkes
