GREASE FIRE
my diesel filter is mounted on the frame rail (because i have a different filter in it's place for wvo) and i need to add some heat to it for cold weather. So i Tee'd off the coolant hose running to the heater core and ran hose to the filter with soft copper wrapped around the filter; then for the return it Tee's back into the exit hose from the heater core that goes to the water pump.
I did this exact same thing a long time ago on my 6.2 van with no problems.
This time, however, the coolant is not flowing the full length of the hose. The hoses get hot a few feet away from where i Tee'd off but down at the filter it is still totally cold. I did take in a short drive on the highway just to make sure it was up to temp & full rpm's and that did not affect it.
Just before it took it for drive i even disconnected one of the hoses just to see if coolant would come out and it did not. I was thinking maybe that would help bleed the air out but there was no pressure at all when i put my hand over that hose.
Do i just need to put some more effort into bleeding the air or is there something different about the cooling system on these trucks than on the 6.2 where i did this with ease?
i know i could also just run one continuous loop from the heater core to the filter and then to the water pump - but now it is cold out and i don't have the hardware on hand to do it and my fingers are still a little numb...so if possible i would like to make the current set up work. Does anyone know if that is possible?
thanks,
Paul
thanks,
Paul
