Fwiw I thoroughly flushed the cooling system and installed a coolant filter four or five years ago. I've replaced the filter three times so far and they always have some debris/sediment inside. Granted it seems to be less and less each time but it's still picking it up.
Same here. Coolant loss while changing it has been a minimal. I've since spaced the bracket out a bit so it's a little easier to get to the fuel filter.
FWIW I installed a coolant filter bypass style without any ball valves. It just seemed like too much clutter. With the system cold and the filter up high in the engine bay I doubt you would loose a bunch of coolant if you removed the filter to change.
