subliminal
yea i read that somewhere, i thought it sounded screwy, thanks alot. what is teh part # for that valve or what do i tell the dealer i need?
What he said...as I understand it, the coolant needs to loop back.
And, I have to ask...why'd you spend $60 on the manual valve setup? The vacuum-operated bypass is only about $20 at the dealer, and at least on my truck, it works VERY well...the heater hoses beyond the bypass valve are nice and cool, and I don't have to go under the hood to switch the valves when I do want heat..
I THINK it's Ford part number F87Z18495AA, and they just called it a valve. Tell the parts counter guy that it's for a '96 Ranger, and it should look like this.yea i read that somewhere, i thought it sounded screwy, thanks alot. what is teh part # for that valve or what do i tell the dealer i need?
Here's a thought for the brass valves...you could install a coolant filter, and use the valves to cut off coolant flow to the filter for servicing it. The filter head won't cost you that much extra, and your cooling system will thank you for it.I didnt think that far ahead, I was leaving on a trip and needed to get it done.
As for the dealer, I have never been able to spend just $20 dollars at a dealer! Everything I go to a dealer for, seems to break the bank.
I am pissed now that I know I could have done it cheaper and had a less ghetto looking setup!
Anyone out there need some brass valves?
