smokin150
aka Diesel Weasel
ok, heres a new problem... replaced injectors and injection pump due to rough cold start/run and the fact that they had about 225k miles on them. now, i changed all that out when the engine was warm and it fired up and ran great, let it sit for two days and, nada, no change. still ran like it was missing on two or more cylinders. dropped it off at a local shop and had them run a comp test on it, heres the results:
cyl 1 -355psi cold 410 hot
cyl 2 -330psi cold 360 hot
cyl 3 -315psi cold no change hot
cyl 4 - 60psi cold 280 hot
cyl 5 -330psi cold 345 hot
cyl 6 - 45psi cold 195 hot
cyl 7- 200psi cold 250hot
cyl 8-365 cold 370 hot
these are the numbers i got from the mechanic when i picked up the truck this morning he thinks rings or valves are shot, im trying to determine what looks to me like the rings are shot from what might be a popped head gasket or whatever. ive had the coolant checked and there are no trace gasses in the system, and im not mixing oil and water, i am however starting to burn quite a bit of oil and its sooting up real bad, like.... the rear pass side of my truck is now black. i need to get this thing going as quickly as possible as im due to head to the west coast for work in a few weeks and dont want to drive the truck that far knowing i have a problem. any advise would be really helpful. i have a machine shop that can do the work (labor) for free if i can get the engine out and down to him. just want to make sure before i jerk this big engine out.... again.
thanks
thanks
