429idi
I did some looking into the hy for my build it seems like I cm male boost down low and still get 20psia?
20psia would be 6.3psi boost. Did you mean 20psi boost?
ok so wats the other turbo then? are you doing true compounds or the ricer thing?
but a modded hx40 and something around stock has decent numbers from what ive figured and may be a good start
I haven't stated anywhere for certain either turbo I'll be using in my compound setup. As stated, I have a total of 6 turbos, all new, here and we are making mockups of how they will physically fit in the location I'm using, how the piping will look, etc... It'll be a compound setup just like the thread stated.
If you think an HX40 and a Stock turbo is a good fit, post up your maps with an explanation how you came up with what you figured..
BTW, I'm curious, when are you whipping out the die grinder and going to town on those heads and building your turbo system?????
As for fitment, you could keep one turbo close to the stock location and run the other on the passenger side of the engine. I have seen a lot of D-max guys do it like that and I've even seen it a few Psd trucks with compounds set up like that. Plus it would be pretty easy to fit.
thx 88. part of my desire to remote mount them is to clean up space above the engine itself. I don't much care for how something as trivial as changing a Glowplug means removing the turbo.
That said, do you have any good pics of what your referring too? The only PSD I've seen twin'd in person, had a turbo off each bank.
You going to update your build thread then?i found maps online but ill look some up then we i get bored
also the turbo system is almost done need an air filter and oil lines and shell be on
yesterday i got a 89 civic to drive so i can have the truck down as needed for work
so the plan is once we get my buddies new jeep ready for plowing
new cam
advance timing
turbo
3 inch dp
5 inch stack
then to find a motor to fully build
