commercial 7.3
Josh Oldenburg
Baileyville IL
I was looking at that one from harbor freight. Lol what are the timing specs for a non-turbo? I forgot and I'm too lazy to look it up Right now
Sent from my Pixel 3 XL using Tapatalk
I believe that it's 8*-10*. At the shop I used to work at, we felt that the N/A engines ran better closer to the 10*. Turbo engines seem to like it better with less advance. After thinking about it, the specs may be 8*+/-2*.
Josh Oldenburg
Baileyville IL
yup thats the 5.4 in the super duty with my truck side plow mount that i made for it. The fan does look aggressive thou
Josh Oldenburg
Baileyville IL
Up close pic before coolers were removed
Josh Oldenburg
Baileyville IL
Where does the long section of yellow wire go?
Josh Oldenburg
Baileyville IL
Okay found one on my parts pump. However when I put power to it it does not move unless I first give a throttle then it will stay extended does that mean it's weak?
The_Josh_Bear
Western WA
That's just how they work, needs driver input to advance.
MadScientist
