Josh Oldenburg
Yes the o-ring was lubed prior to install. I listen to the filter reset the o-ring tighten the back up and it did the same thing. I then removed the tapered o-ring and found a square o-ring off an old filter and put that on. As I was screwing the oil filter on I noticed the body of the oil filter was kind of tapered away from the surface of the oil filter housing. Only in one spot. So I sent the wife to get a new oil filter because it pushed the square or ring out as well
Sent from my Pixel 3 XL using Tapatalk
