Teipsum
Hey guys, a few weeks ago I installed a new IP from Agnem and it is a whole new truck. However, now with the arctic temps in the south I found a new problem. Starting it in a cold morning produces 3 minutes of intense white smoke and it runs a bit rough (kinda like a miss). But once the temp hits the bottom of the "C" on the temp gauge it immediately smooths out and stops smoking. The truck has new glow plugs (well 7 out of the 8...haha) with manual push control for the plugs. After holding the glow plugs on for 8 seconds the truck fires right up, so I dont think it is the glow plugs. Or could it be the 1 glow plug #7 that I didnt change? Or would the smoke/rough running be caused by the cold solenoid switch as the problem immediately goes away once the temp rises?
Also the truck does have newer (10K) injectors.
Thanks!
Thanks!
