cold miss
69oiler
I don't feel tardy
Chardon OH
ever since i got my new exhaust i have notices what sounds like a miss at idle when cold. there is a distinct **** **** **** at the tailpipe sounds just like a dead cylinder until i get a reading on the temp gauge. i dont think it's related to the MBRP other than the fact that i can now hear it without the muffler and cat in the way.
once it warms up it sounds fine. EBPV is unplugged. 8 new GPs. power is low with a cold engine as well, until now i just figured the computer was limiting power but now i'm not sure.
any ideas?
Mike
Stroker
Cora
You need to do a buzz test or a CCT.
Mike
Stroker
Cora
buzz test will test the solenoids on the injectors to insure that each injector has a functioning solenoid, a CCT is a Cylinder Contribution Test............
apextrans
What Log Book????
Fallston, MD
I had what you're describing right after I bought mine. I had two injectors that were dead until the motor warmed up. Tbirdfiend did a buzz test for me & that was the result. I had others that were only operating @ 50% until warm too.
I don't know if CCT is the same thing but along with a buzz test they can do an isolation test to see which injectors are doing what.
If you get a tapping on start up when cold, get it looked at before you go down the road I've been down:puke:
jorge140
