chip codes...............
geonc
SPIDER BAIT
NECKVILLE North Carolina
Anyone up on their chip codes.......I was under the impression I had codeTDEO.....but written on the PCM cover is ALF4...different code speak?
Truck info is in sig.............cornfuzed :confused:
Max Power
What does it say on the door jamb? PCM cover is likely correct unless it has ever been reflashed.
Ford_Forgotton
Here is what I found with a quick Google search:
PCM Chip Codes 1994 - 1997
94 manual - BEG6 BEG 8
95 manual- SOD4 SOD5
95 auto - PRY4 TEE4 TEE5
96 manual - ALF4 AUG4 AUG6 AUG7
96 auto - MIF4 MIF6 MIF7 NAW4 NAW6 PRE4
97 manual - ALF6 JKA2 JKA3 MLE0 MLE1
97 auto - MME2 MME3 MME4 MME5 MME6 NAW6 TDE0 TDE1 YBT0
geonc
SPIDER BAIT
OK.................year is correct for the ALF4....why did I think I had a '97 auto
code chip? and if it did :eek: what could happen?
Ford_Forgotton
Shrug, usually if you have the wrong chip for your code, the truck either wont start, or will do "weird things". I dont believe it will hurt anything tho.
Mike
Stroker
Cora
geo,
Are you sure that at some point in time your ALF4 hasnt been reflashed to the TDE0?
SeeYa
OB Vendor/ DP-Tuner
Asheville,NC
geonc,
The Alf4 code is for a dpc-203 '96 truck. The TDEO code is for a dpc-202 '97 truck. Better double check, you can have any of these codes flashed to your dpc-203 PCM,
AUG4
ALF6
BEG5
AUG2
AUG7
MLE0
SOD4
SOD3
AUG6
SOD2
AUG1
SOD1
ALF5
GOB0
BEG8
BEG6
SOD5
ALF4
ALF0
ALF1
ALF2
MLE1
AUG5
AUG0
AUG4
ALF6
BEG5
AUG2
AUG7
MLE0
SOD4
SOD3
AUG6
SOD2
AUG1
SOD1
ALF5
GOB0
BEG8
BEG6
SOD5
ALF4
ALF0
ALF1
ALF2
MLE1
AUG5
AUG0
AUG4
ALF6
BEG5
AUG2
AUG7
MLE0
SOD4
SOD3
AUG6
SOD2
AUG1
SOD1
ALF5
GOB0
BEG8
BEG6
SOD5
ALF4
ALF0
ALF1
ALF2
MLE1
AUG5
AUG0
AUG4
ALF6
BEG5
AUG2
AUG7
MLE0
SOD4
SOD3
AUG6
SOD2
AUG1
SOD1
ALF5
GOB0
BEG8
BEG6
SOD5
ALF4
ALF0
ALF1
ALF2
MLE1
AUG5
AUG0
Hopes this helps!
