94turboidi
Okay I finally fixed all my little stuff on the truck this morning and went to back it up after I started it. I have a new master cylinder, slave cylinder, pressure plate, clutch, clutch fork. I bled it the other day and I think all the air is out, its moving the clutch fork at least an inch if not more so I figured that would be enough? This is a zf5 and 7.3 just so you know all the details. I don't know I guess I will try to bleed it more but I figured this would be enough movement. The clutch fork seems to be installed correctly its snapped into the pivot ball. My other parts were hard to get in gear also and it was barely moving the clutch fork, thats why I thought this would work fine with as far as its clutching. I hope I didn't do something wrong and have to take it all apart! This is my first manual trans but everything seems to be installed correctly. I have done plenty of engines, transmissions but no clutches until now.
