Ah, you are correct. Each of the 2 shift rails on the NP205 control the front and rear outputs seperately. The NP203 can also be twin sticked, but each of its 2 shift rails are a bit different. One controls the range selection and the other controls 4x2/4x4. I must have been thinking of the 203 with the offset rear output from a NP200. Can't recall if the 205 has that ability. I know the 208 doesn't as the parts of the case not used for output shafts aren't cut (no cover plates like the 203).
