squoril
noticed im getting leakage that's then getting slung everywhere by the drive shaft so i want to replace the pinion seal
after looking into it it sounds like i have to mess with the bearing preload when i resemble it
it looks like there are two methods i can use are:
put the bolt back on the exact number of turns it took to get off
jack up the rear end, take the tires off, read the tourqe it takes to rotate the pinion
put a new crush sleeve on and keep tightening it tell the tourqe it takes to turn the pinion is the previous value + 3
is this something i should even attempt? it seems straight forward to me but i dont know if there are any pitfalls to it
