Jack front end up
remove tires
remove brake calipers
remove locking hubs
remover wheel bearing nut(s)and outer wheel bearing
remove Dually hub and rotor with inner wheel bearing.
Install single wheel hub and rotor with inner wheel bearing(Dana 50 or single wheel dana 60)
install outer wheel bearing and wheel bearing nut(s)
install locking hubs
install calipers
install tires
Let off jack
