Cab corners? what manufacturer?
junk
Paullina, IA
I'm looking to get cab corners for my truck. What's a decent manufacturer?
RockAuto sells sherman cab corners, but I can't tell from the picture if they are just the corner, or include the lip that goes into the door opening.
CCG Truck has corners also and they look decent like what I want for a decent price.
LMC truck has corners for about twice what Rock or CCG truck had them for. If I really thought they were worth the money I'd pickup a set.
I still have to check out some other places, but thought I'd check here to see what people have had good luck with. I'm pretty confident that any aftermarket cab corner is going to be thinner than the factory tin. I'm also concerned about fit. Being it's a cut and weld in part I'm sure it will have to be worked to get it to fit correct to the rear doors.
Thanks,
Jeremy
Dsl_Dog_Treat
Decatur,MI
The Sherman ones is what you'll be happiest with. The last set I got from them did have the lip that wraps into the door opening.;Sweet
Keystone is also another supplier with decently priced metal.
Keep in mind that aftermarket skins are not as thick as OEM metal tho.
junk
Paullina, IA
Looks like I'm getting a set of sherman's then. Thanks for the recommendation DSL_Dog_catcher.
m2rtin
