bronco78idi
Hi all,
I have been researching over the last 6 month reading and adding info on how to build a 6.9L with a turbo. I have found great info but it always lacks the detail of spec and parts name of manufacture used.
My engine is at a machine shop here is what I am having done but I put it on hold for now while I find some answers to the following questions. My use Daily driver and off road fun. Any help on this would be great. This is my first Diesel.
1. Valve job
2. Deck the block true
3. Line bore the crank to cam
4. Balance the block
Question I am looking of help on.
Lower end Questions
Can you find 6.9l rods with larger wrist pin like the 7.3?
What is the best manufactured Piston to use?
Should I shave piston down the piston to 19.5:1 or 20.5:1 to get more boost from the turbo I am adding?
Would you stud the lower end?
Is there an oil pump that pushes more volume? and what is the best manufacture to use?
Heads.
I have already had the valve job done, but now I am thinking I should have then tear it down again.
Should I have used 7.3L Exhaust Vales? And what is the size difference. I also was reading about using 60lb springs and retainers. But they never said who made them.
I am already using the 7.3L Rockers and assembly and ARP Stud KIT, am I missing anything more?
1. Valve job
Lower end Questions
Heads.
