Brownie over/direct/under value?
GenLightening
Yeah, it's a CHEVY!
Pukalani, Hawaii
I scrounged through the rubber mount selection at the Kenworth dealer and found some that I made to work. I can take some close up pictures of the setup I rigged in there if it'll help you any.I rigged them with long bolts with a number of spacer washers on each side so I could adjust the angle of teh box to adjust the ujoint angles if needed, which came in handy. I was able to get a vibration out when I first installed it by moving a few washers
Since I'm picking up a brownie now, can you send me some pics of your install?
bghnkinf350
Bay Area, Ca
Sort of unrelated but mine keeps popping out of direct and there is in and out play on the mainshaft. Can these be shimmed? Is my retainer possibly bad?
ntjapkes
