Bronco Fuel Tank Install
hacked89
Bucks County PA
So I do wonder, what tank it is that I have? Thought it was a 38 gallon, but may be smaller, and it is plastic? So… wonder what size it really is… has a skidplate which IMO is a must, especially in the precarious places my trucks wind up in… would hate to punch a hole in the bottom of the tank… that would be bad…
I’m fab’n a 19g f350 tank tucked up in the rear of the bronco for off roading, you mentioned precarious places. Maybe an idea for you if it’s an off road rig.
u2slow
bilge rat
Coastal BC
The only plastic tank I've found in the bricknose/OBS is a rear cab&chassis type. I still have it. More cube-like than a pancacke. It fits between 34" frame rails, whereas the pickup/bronco frames are ~38" wide.
That must be where Selahdoor's came from then. I haven't seen a plastic tank in out trucks, but also haven't paid a lot of attention to C&C trucks.
KansasIDI
Hopelessly addicted to IDIs
Wilsey, KS
Well that truck that has that tank is in fact a c&c. Probably won’t work in my F250 then?
