I have the aftermarket in the head and the original gauge in the original location. The "O" is about 190F and this also is the same reading on my old gas 1980 f150 I used to have. The old f150 had a 195 degree thermostat, and I could watch the needle on very cold mornings bounce off the "O", when the thermostat opened up and then shut again.
Alright, so I guess I was indeed running cold on this last trip I just made - this would definitely explain some of the poor fuel economy. Do you think retarding the IP slightly from its super-advanced position could have caused such a drop in engine running temperatures?
So ideally you should be near the "O" or a little bit above if you are running the factory thermostat. When I still had my overtemp sensor installed, and I was having overheating problems, it would not let the guage go much past the "A" before it pegged the needle on the factory gauge. I don't think the factory gauge could ever read over to the "L" with the overtemp sensor in place, since it must be higher than the overtemp sensor trip point.
Alright, so then for the last two years I was where I should have been. Also, I do not know how the factory overheat switch factors in the whole mess, but have actually seen my gauge go up to "L", shortly afterwards the red engine light came on but at this point I was already pulling into a parking spot so I was able to shut it off immediately and disaster was averted. Gauge never actually pegged on the high side during that occurrence.
I had a really top heavy girl with a low cut blouse in my truck so no, I was not watching the gauge.
I was purposely hitting the potholes that day.
Oh, you mean a girl like the one I just kicked off my laptop?
(bubblegum, she's visiting for a few days, her truck needs some repairs and she could use some company for the holidays anyways) Not quote sure tho how you hitting them potholes intentionally made your engine overheat... And why in the world were you hitting the potholes in the first place, all they do is jarr your teeth and sometimes make your head meet the cab roof, lol
Also, when my engine light came on there was no damage to the engine, I think mostly cause I shut it off immediately and gave it plenty of time to cool off before restarting. It's a darn good thing she survived tho, cause it happened in downtown Chicago
