Brain trust questions
Clb
Another old truck
nannyfornia
What's it take to put group 31 batteries into an obs?
I hunted the post where someone did an upgrade and built new boxes but couldn't find it.
I have 2- 6 mo. old batteries in the 5er that I want to upgrade and the ferd is due for new ones.
thanx in advance
chillman88
Central NY
They fit fine in my 91. I believe what I had seen for the OBS was just lowering the trays about an inch. I think they cut the mounting tabs off and put some 1" flat bar in to drop everything down. That's just going off memory though.
  • Like
Reactions: Clb
Clb
Another old truck
nannyfornia
:thumbsup:that'd be cool, thanx I will do a clearance check then. you saw the same thread I was thinkin on...
when i did Andrews truck, i didnt like how they fit with the factory battery trays.
i dropped them down an inch.
then ran new cables.
bring some 1/4" 1" strap, some 2/0 lugs, some good shrink wrap, and a 12 pack, well get em done
Clb
Another old truck
nannyfornia
So you just sectioned the mounts and dropped em an inch?
I've not had them out to look yet.
I replaced the Eastwood welder with a Miller :sly
How was the vaca?
See you soon
How was the vaca?
See you soon
yes sir. its actually very simple for the like minded .
summer is skrewed with family sheet but i need to get out on the trail!
need to replace fuel pump now... so shake own is almost done and i can finish the chero
  • Like
Reactions: Clb
Nanohawk
