Bouncing tachometer
carrasco4712
US
Anyone know what issues cause this? I'm thinking it's just the wiring but it's hard to tell. From listening to the engine you cannot hear an idle difference.
Sent from my E6830 using Tapatalk
carrasco4712
US
I had to look that one up-the speed sensor. I'll try that and update, thanks.
snicklas
6.0 and Loving It!!
Staff member
Greenfield, Indiana
Why would the VSS effect the tach? The VSS is for the speedometer.
I would remove and clean the tach sensor mounted in the IP Gear cover near the oil fill. It is the large ~1" nut with the 2 wires coming out of it. If cleaning it doesn't work, you may have to replace it. Do you know someone else with an IDI that you could possibly borrow a known good sensor to verify, since a replacement is ~$60+......
Now, if the speedometer was bouncing, or the E4OD (if equipped) were in limp mode, I would check the VSS..... but not for just the Tach bouncing.......
Or if you have, or know someone with a laser tach you could also verify if the engine RPM is really staying steady, if it sounds like it is, it more than likely is, but is another option for verification......
carrasco4712
US
But I already put a new cam sensor in like 2 months ago
79GLIDE
Omaha
Had a similar problem, turned out to be near fractured wire near pigtail on sensor.
carrasco4712
US
Oooo, yes
My wires are in bad shape. I'm slowly replacing all of them.
IDIBronco86
Staff online
