I like it real well so far Rob I have a first gen edge evolution for my 96 I ran on the 03 for a bit and I like this second gen a lot better. With the first gen on the 03 the throttle was real touchy and the second gen feels a little more like stock so you can actually ease on the throttle a bit but then a little bit more and your going. It was a piece of cake to install it took me about an hour and half from start to finish. The only thing really involved in it is drilling and tapping for the pyro probe then run the cable up in the cab everything from there on is plug and play. I have not messed with the tranny shift points yet but it actually has more options then advertised. You can create a custom tune when you are power programming and you can adjust rev limiter, motor timing, WOT shift points, normal cruise shift points, shift firmness, and WOT fueling. I think for the money its a heck of a deal with all that you can do with it
