With studs, 20psi will be pushing it without dropping compression. I think if you want to push that much boost, dropping the compression would be fine. It would also give you ample time to stud the intake and exhaust manifolds. But, your turbo might be out of its efficiency range right now, super heating the air. Its non gated so it will be able to push more boost without superheating than a wastegated turbo....but I think the boost your running at its going to be headed out of its efficiency range.
