neither side of the fuse gets power when i jump power it starts working so hopefully ill get it figured out
this weekend im putting the hydro boost on elec vac pump for a/c controls and my carrier lift pump so ill start messing around with that hope fully today after work
The basic premise is that the fan has power going to it all the time. The switch controls the fan motor path to ground, either directly (high speed), or through resistors (less than high speed).
when i jump power every thing works properly the varibale speed fan is working so does that mean that there is a fuseable link in the dash some where that im missing i just dont want to go chasing wires all over the place has anybody had this problem before
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
