Cheaper Jeeper
Got a weird one guys.
My truck has a block heater installed, but the PO (the truck is from California) cut the plug off the cord. No big deal, just get a new piece of 3 conductor cord with a 3 prong plug, and splice it to the cord that's there, right?
So I did just that. Both cords have a two 14 gauge wires, and a lighter gauge green center conductor. Easy-peasy. Spliced 'em together and plugged it in and ...FIREWORKS! Sucker made a big flash, threw sparks, and tripped the breaker - but not before welding the prongs of the new plug into the socket of the extension cord!
So I managed to get the prongs out of the socket, and everything still looks usable, so I go get my volt/Ohm/amp meter. Now let's call the 2 flat prongs #1 and #2, and the round grounding plug #3. Using the Ohm meter I measure ~ 15 ohms between 1 & 2, and the same between 2 & 3, and the same between 1 & 3.
So I do a little math.
Volts/Ohms=Amps, right?
So thats 120 Volts / 15 Ohms = 8 Amps, and the 14 gauge wire is good for up to 13 Amps. So far so good.
Volts x Amps = Watts, right?
So that's 120 Volts x 8 Amps = 960 Watts. So it must be a 1000 Watt (nominal) block heater.
So why the HECK is it tripping breakers and behaving like a dead short? Is there something I'm missing here?
Anybody with a block heater installed got an Ohm meter and would be willing to take measurements between the plug prongs #1 & #2, #2 & #3, and #1 & #3, and post the results here?
