rodymartin
I wrote earlier about my head bolt problem. Well today we pulled the heads and this is what we found Any Ideas???? It looks like water was in at least 2 cylinders.
Rody,
That's pretty common in a motor that's been sitting unused for a while. If I remember correctly, it has been sitting for about 4 years. The valves may have been open on those cylinders and condensation/rain did it's worst on those cylinders. Usually, it's not too bad and can be cleaned up on the heads and honed out of the cylinders. But the rings may be stuck.
I wouldn't hurt to take it down and have the corrosion cleaned up and put a set of rings on the pistons if everything else is up to spec.
No water in the pan? If so......the bearings may be shot.
Heath
id second that onethe time and money you spend now will save you in the end.
Sounds like the main and rod bearings are fine. Some would just "run" it like it is..........but I think it'd be best to hone those cylinders and at least re-ring the affected pistons.
Heath
