dyoung14
Is getting worn out
well i figure 30 lbs is obtainable with overtorqued head studs but have not got to testing
the twin compound i had planned would be 30-60 the point just below failure
but the issue was how far could it go
that 1200 hp idi was a beast running a ton of boost but the block was like jello
To make that much boost, you need to come up with a formula to lower the compression just a certain amount that was the effective compression ration stays the same as it is now, that will be a more effiecent engine than just going into the build blind and just lowering the compression some crazy amount, but however far you lower the compression your gonna have to have a heck of an IP and injectors to fuel enough to make up for the compression loss
