black brake fluid
mcbg
az
My brake fluid has been slowly needing refilled-mostly the front reservoir.
I syringed some out and its very dark black. Is this a problem?
Thanks
LCAM-01XA
my very own hell
Yeah, tis a problem - you gots lots of moisture in that brake system, I recommend pulling the rear drums and inspecting the wheel cylinders for leaks (the cause for your slow fluid drain) and replace as necessary, then flush the whole system with clean brake fluid.
M
maxdiesel
Guest
I always thought in addition to moisture and flushing it's a good idea to replace the rubber brake hoses. I just did this on an s10 and the hoses were defiantly getting soft.
LCAM-01XA
my very own hell
Well water in the fluid don't necessarily mean the hoses are bad, but yah, tis a good idea to check them for cracks and stuff, and replace as necessary.
