Big spare tire mounting?
zrexryder
Sacramento,Ca
I was at pick n pull today and was checking out bronco spare tire mount to use to hold up my 37 inch tire.Has anyone ever mounted a bronco sytle spare tire mount on there truck?
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
biggest issue with them is it hangs all that weight off the bedside. your bedside will splay out just from the weight. i would look into the ones that mount to the back bumper and swing outa the way if u really want it on the back.
tknomaj
Anaheim Ca.
Also, on a Bronco, isn't there an integral support inside that corner?
Yes it is but even with the reinforcement it will not support anything bigger than a 31 with out damage to rear quarter panel . 37's are out of the question. If that is what I was looking for find a rear bumper from a hummer it has a tire rack on it that will hold up remove it from bumper and build you own bumper and use hummer rack.
