david85
No one tried to simply pump the clutch pedal?
Make sure the master is pumping, then push the pedal to the floor and hold it there for a couple minutes, slowly let it up, sit a bit then do it over and over till its bled, it takes some time for the air to rise up to the master , if you pump fast the air just moves back and forth in the system.
I have done this many time with great success.
