mexicanjoe
question: is B-12 or Seafoam safe to use in idi n/a engines? How much is needed ? What if I look for ? I'm using Marvel Mystery Oil right now
Just be aware that we shouldn't need any 'stiction' products - the main goal of these products is to handle gummed-up HEUI injectors due to crummy oil / not changing it frequently enough. IDIs don't have HEUI injectors, so no need to clean them.I didn't say Seafoam is bad, I just moved on to better product for Diesels. I also use 'stiction' and anti-wear lubrication products. A lot of products have come out in the past 3-5 years that are not 'Snake Oil'.
Many diesel specific additives out there that I’d rather use in the fuel. I wouldn’t recommend dumping it into the intake to clean carbon out you’d have better results giving it some good throttle on the on ramp to the highway now and again and burn it out. I know if I just putt around town for days I notice my truck starts acting different but 10 minutes on the highway and it seems to clean it out and make everything normal again
Stiction fighter does it's job in our IDIs. MMO is great also to add to every oil change. The stiction fighter is used in every 4th or 5th oil change in place of Qt or 2 of oil. Cleans burnt-in crud deposits on engine & turbo internals. We have IDIs, PS 7.3s, 6.0s, Cummins, Benz & Hino lawn mower trucks in the families around here using these products.
Works for us!
Just an opinion..... not trying to start he additive/oil argument......
