Bedside support, exhaust hanger part numbers?
marmot
On the bench
Twin Bridges, MT
Just crawled under the 1993 f250 to see why the exhaust is at such a strange angle, there are at least 3 missing exhaust hangers that have been replaced with barbed wire:idiot: Are the exhaust hangers ford parts? or standard exhaust stuff and where does one procure such stuff. Also the support for the drivers bedside is missing, one chunk of it is still bolted to the frame bracket. Anyone know if that has a part # or where I can find one. Thanks,
Marmot
i took mine off and made my own.
in the morning, ill check to see of i still have them.
marmot
On the bench
Twin Bridges, MT
Thanks man. I have done a bunch of looking on body shop supply sites but still no bedside supports that I can find, anyone know what they are called it is the strut by the wheel well?
marmot
On the bench
Twin Bridges, MT
10-4 I figured as much. Anyone know what the heck that strut/brace/support that holds the bedside square is called or is it a junk yard part?. You can see it if you look in the wheelwell and look toward the front of the pickup.
is the hanger on the exhaust pipe still there?
i have the upper mount, but if the rod isnot welded on the exhaust,
youll have to weld it, or take it to an exhaust shop.
summitracing.com carries bolt on hangers...
marmot
On the bench
Twin Bridges, MT
yep the "bosses" or what you may call it, are still on the pipe and the frame, the actual hangers are broken and replaced with barbed wire. She must have caught the exhaust on something and torn it up. The pipe is almost new looking with no rust as is the muffler. I might just drive it over to the muffler shop. I found a 88 regular cab gasser at the yard last week so I may see if that strut is the same.
Oh. Lol
Well just grab the "isolators" then.
I'm not sure how important it is, but the factory ones are metal reinforced.
i have 1 of the first and 2 of the second
this is what i did
