barely any heat in cab, seems radiator/water pump below temp as well?
CaptTom
ca
Aluminum is very conductive. Lol
Basically you add a ground to the heater core.
:***:Did I write!!! LOLLOLLOLLOL What a maroon!! Sheesh.
Because it is so well insulated, how is it corroding through the fresh water circuit? It's totally surrounded by rubber, plastic or foam, and attached to rubber!!
There... that's what I was thinking.... I thought.... sheeeesh.... obviously the coffee hadn't kicked in yet, and stupid was at full throttle!!!!
Will solder on one of my "aluminum" eyelettes, and run a ground wire. I still can't believe I said that in public.... :frustrate:frustrate:rotflmao
Read up on this thread, it’ll make you fell better about that mistake!
https://www.oilburners.net/posts/924571/
CaptTom
ca
LOLLOLLOL
Thanx for the moral support!!!
I'm gunna drive my burner home now, and open some bourbon.... I might just smell it, don't wanna risk another ridiculous post in the same day!! :fan::joker:
Have a great weekend!!!!
Capt,
The electrical current is in the coolant, so in this case, all the rubber hoses don't matter.
I've seen a test with a digital meter, where you put one probe tip in the coolant and touch the other tip to the battery negative, and you can measure several millivolts between the two.
http://www.ve-labs.net/electrolysis-101/how-to-test
