Bad Injectors = Exhaust Leak noise?
wbw189
Metamora, Michigan
Hey,
I am ordering new injectors for my 6.9 soon. I have noticed over the last year that I have what sounds like an exhaust leak, but I can't find one anywhere. I have what looks like the original injectors and pump and X85,000 miles on my truck. Is it possible that these old injectors could be causing that noise?
Anyone know a good diesel repair shop close to Lapeer, MI?
Let me know what you think...Thanks,
Feel your injector lines and see if any of them are hot. An injector with a stuck pintle can make that kind of noise... it's the sound of exhaust gasses being forced back up through the injector.
wbw189
Metamora, Michigan
Thanks, Mel and Brian.
I will check the injector lines tomorrow morning. Would this be something that is intermittent or open continuously?
Thanks,
wbw189
Metamora, Michigan
I checked the injector lines when I got to work this morning. They were all fairly cool to the touch. I notice the exhuast leak more at higher RPM. At idle their is a slight miss. When I hear the miss, the engine shutters and I see a small pull of white/gray smoke out the tailpipe. I have cracked each injector line and each one caused the engine to stumble.
Thanks for your input,
placidoert
