Pipeliner_86
IDI up high
I bought a truck up north of Detroit last week. Its a 1994 F250 4x4 ext cab, ZF-5 speed with 296,*** on the clock. The turbo is a garrett, but it doesn't have the black ATS peice on top of the motor like most factory stock idi turbo's had. I can't find anything indicating what turbo system it is, the intake hose from the turbo to the air filter looks like a homebrew job. Blue flex-plastic hose with a knock off K&N style filter on the end. I'll throww up some pics when I get a chance. The truck is gonna be mine to drive, my wife finally got her way and is gonna start driving my Dodge.
The CDR valve is plugged into the drivers side valve cover and the hose off the CDR is pointing towards the turbo, venting all the blow-by into the engine compartment. I'll proly just make a RDT, keep it simple I guess. All in all the truck drove ok, the front drive shaft is off, and the front axle hubs were locked in the whole way home. I couldn't figure out where the vibration was coming from,until I looked at the hubs when I got home and realized they were locked in, spinning the entire assembly at 70+mph down I-94. It was dark when I got the truck, plus pouring down rain, and the stupid wipers would work (slowly) for about 8 seconds then shut off for 10 sec. Pev. owner said the drive shaft was off because he lost the u-bolts, and he was worried about the engine oil pressure, other then that it's supposed to be a " reliable" truck. It held good oil pressure all the way home, which is about an hour and a half drive on the interstae. Towards the end, it started th dip toward the low side, but never dropped out of good operating range. My old 86 I used to have never did read " good " oil pressure. The clutch felt tight, and the gears shifted well, no grinding. This was the main reason I jumped on the truck was that it had a fiver, and I was tired of automatics in diesel trucks, I was gonna buy a diesel with a hand shaker Much more enjoyable to drive than a slushbox
I'll put up some pics when I get a chance, I haven't started working on the truck yet, I am wondering what other mysteries I'll find.
