ATS 093 Turbo and Water to Air IC
Ok instead of starting a new thread, does anyone have any idea why my "new" clutch that really only has 1500 miles tops on it, wont engage?
Throw out bearing getting caught up on the shaft? It engages just barely enough to roll and I can get it to back up in the driveway if I push the clutch in then dump it. Ive pulled the inspection cover off, there seems to be plenty of clutch material and Ive had a buddy watch the clutch engage while I'm inside pushing and releasing the pedal.
I'm stumped and at a total standstill with this truck.
i take it you smell burning clutch material?
how long was it sitting?
bajabomber87
Salinas, CA
No clutch smell at all. Only thing I can come up with is the slave is sticking. I have a brand new bendix slave but I dont want to use it if I dont have to, would rather return it and get my money back lol.
The truck sat from this past December till 2 weeks ago. Its weird, when my buddy first rolled it out of its parking spot for the past 6 months he tried bump starting it and it dragged the back tires down his hill (paved). but now I cant even get it to barely engage besides 4 low and bumping the clutch.
discbrks
Columbus, GA
Man that thing sounds good! Don't forget to turn up the IP to get the most out of the turbo.
I had this problem with the Night Moose when we first put it together. Turns out the Fork was not in properly. I'd check that first.
Whats the story on no wheel wells?
bajabomber87
Salinas, CA
Already did, its 1.5 or 2 turns up. Complete pain in the ass to do LOL
Hmm might be, just weird how it worked perfectly then stopped all of a sudden.
On the wheel wells I trashed them because they were old cracked and the insulation on the backside was just falling off and making a mess. If I ever reinstall inner wells I'll make them out of sheet metal.
bajabomber87
Salinas, CA
Ok question on my gauges I'm about to get, its an A pillar 3 pod setup with boost, pyro, and trans temp.
I wanted to use the trans temp gauge for the intercooler. Should I put it in the radiator for the intercooler or would it be more practical to read the actual air temp on the "cool" side of the intercooler just before the intake? Gauge reads 120*-300*'s fyi.
dyoung14
Is getting worn out
spencer,tn
i would put it were it reads the air tempurature right before it goes into the engine
bajabomber87
Salinas, CA
Great. Anywhere to get a cheap one or should I just get a South Bend conversion?
Ok the dmf clutch itself has 5k miles on it so its still new, I can get a smf "conversion" flywheel on rock auto for $123, will the same clutch and pressure plate work on the new smf fly wheel or are they different and only will work with a DMF setup?
RangerDanger
