Anyone use centrifuges before???
Andylad13
DieselBoy
Connecticut
I'm looking up many sites and they all have the same exact info about centrifuges, but no prices or anything. Has anyone used them on these engines?
flatlander
plays dirty when losing
ft. wayne IN
I figured you spelled it the way you wanted it, but the only centrifuge that came to mind is the ones that they use to make nuclear fuel. Say, you're not an Iranian are you?
mcbg
az
how about a centrifuge for a bypass filter, anyone used these on our engines?
these are gravity feed cf
simplecentrifuge.com
absolutecentifuge.com
this is the closed system type cf
dieselcraft.com
subway
be nice to the admin :D
York PA
no but i have thought about it, i think the centerfuges need 40 psi to start operating right. trouble is my trucks max oil pressure is about 40 so it would be below the min operating pressure of the centerfuge.
i am taking my reading off the turbo though so it might be higher if i tapped the block.
for 180 i figure its cost competative with a bypass system with no filters to change again.
Andylad13
DieselBoy
Connecticut
Yep, no filters to change except a piece of paper. What you guys are talking about is what I was looking into.
F350farmboy
The Hornet
N.E Ohio
I've just started to look into these....they seem pretty cool, and cost effective. They say they filter better than regular style filters and like you said, they dont need changed, just cleaned.
subway
York PA
Bradz
