special tools... you will need a ball joint press, i rented one for free at Autozone. a good vise , and a couple sockets for changing the u-joints. snap ring pliers. the pivot bushings you can use the ball joint press as well. you may need to peen back the lip on the old pivot bushings, mine were kind of flared. you'll know when you see it. you will need the special socket for the wheel bearing nuts, $18 at Autozone.
the hardest part is getting the spindles off. the easiest way i found is to apply pressure with a jack at the very end of the spindle, then use a block of hardwood and a cold chisel and beat the heck out of the spindle and try and get the chisel behind the lip in the spindle. it is a real bear to get off there. by applying pressure with the jack, you only have to pry at the top and the sides ot the spindle, the jack is working from the bottom.
really, other than a lot of hard work and sore muscles, the job isn't all that bad. the TTB is really pretty simple when you break it down, very straightforward assembly. just have a look at it, there arent a whole lot of surprises. this is 4x4 though. with the 2xd there are a few different parts i wouldn't know about. on the 4x4 you do have to pull the diff to get the c-clip for the center shaft out to change the center U-joint.
it was almost so easy i wondered if i was missing something. if you have the time and patience, i would recommend doing the work yourself.
i got the Energy Suspension poly bushings for $33 shipped from Summit Racing. they're not in the catalog, but if you call them they do have them. the rest of the parts i got locally. be sure to spend the money on the good joints with grease fittings, and the needle fitting you'll need to grease the U-joints. it is so worth it.
there is definitly a feeling of satisfaction from doing it yourself.
ROB
